JBDdsmer610
- 508
- 8
- Mar 4, 2006
easton,
Pennsylvania
Ok guys I'm having issues going into boost once I hit operating temp. When the car is still a little cold like inbetween 130-160 degrees the car run great and hold a sold 14psi. Once the car gets to operating temp the car runs like poop even when starting to get into boost the car stutters and craps on its self then when it dose get into boost it won't hold 14psi it creeps almost up to 22psi. The previous owner had a maf translator on the car witch I remover and went back to stock mas. I'm running a full 3in turbo back, intake pipe, full short route FMIC, ported 14b with stock mani, hall man pro boost controller,K&N filter, NGK wires and bran new bpr6es plugs. And I do also have full V3 link converted to SD it's just not installed yet bc I need to get my wide band bung welded in. It's just stumping me that it runs perfect and when it's kinda cold then it gets hot and it's CRAP!!!, and even when it's hot and I start getting into boost it start stuttering and breaking up a little and I have to get of the throttle then get Back in it but it still has the same issues boost really slow then wants to spike go over 20psi...I'm stumped some help would be great guys
