brynden29
20+ Year Contributor
- 127
- 0
- May 15, 2002
Round Rock,
Texas
Hey guys,
I did a lot of searching and everything I found pertained to 2gs.
I just installed my MTX-L o2. Everything went fine, I wired the yellow wire to the ecu, (pin 4 - white wire) enabled the narrowband sim, selected the input for LC-1 Wideband, changed the W/B drop down to front o2, and did the open air calibration. When I fire it up, the gauge seems to work but the ecu reading for the o2 is stuck at .80 and the LC1WB value is stuck at 7.4:1.
I am not sure that I tapped the correct pin. Can you look at the attached pic and let me know what you think?
Thanks so much.
Thanks so much.
