mitsumike0
- 210
- 46
- Oct 13, 2013
Passaic,
New_Jersey
Alright so i need to know if this true or not. About 2 months ago, i fixed my cracked oil pan and put rtv(the right stuff by permatex) on the pan. I go under the car the other day and its wet around the bead of rtv and i see motor oil building on the tcase. So me being curious, i grabbed my 10mm ratchet to see if they were lose and believe it or not, some were! After the rtv dried that day, i rechecked to see if everything was still in spec and everything looked fine. When doing this job, i reused the old bolts because my new bolts did not arrive on time and i needed the car out of the garage. Do these bolts stretch? Should i put my new bolts in and tighten it again?
