Joshosuna111
- 0
- Aug 28, 2015
Anaheim,
California
My clutch is starting to pull , car is an 1995 Eagle Talon Turbo AWD , and i need a racing clutch / stage clutch any recommendations?
I would go with a puck disk for launching, otherwise you'll likely overheat/torch a full face disk. If you want to go full race car, look into multi disk clutchs that will let you shift high enough to smack your stock pistons into your tired old 100k plus mileage valvetrain.I want the clutch for good launching
its not grabbing no more very weak , and recently been seeing the back wheel drives thighten up like if the breaks are onCouple of questions for you:Very little information has been given about the issue that you are having. Posting pics of your disc and pressure plate surfaces may help diagnose the failure of your clutch (if indeed that is your issue) to give an appropriate suggestion. A "racing" clutch will be very harsh on your drive line as will poor driving.
- What is wrong with your clutch?
- How have you verified this?
- What shape is your hydraulic system in?
