nwsalty
- 2
- Jul 27, 2015
warrenton,
Oregon
There is a galant gsx. They are non turbo 4g63 powered, and use the weaker w5m31 transmission, with a different rear end ratio.Its called a Gallant GVR4. It will be a 91-92, and it will have a numbered badge on the dashboard. It is a 6bolt motor in it the same as the turbo eclipse or Talon of that year. The rear is different, however most is the same. So its no called a Gallant gsx. I actually own one.1341/2000
