Rear corner blinkers don't work
XIT
63
9
Jul 20, 2015
Wisconsin
On both sides the rear corner blinkers don't work. It's not the bulb the bulbs are fine even when I switch bulbs they don't work... is it something with the wiring? I have no clue and no direction so any suggestions are appreciated. Thanks in advance
If the front blinkers are working then your turn signal relay is working. You replaced the bulbs so a wire is disconnected somewhere or the bulb housing has corrosion or dirt in it preventing a good connection. First off I'd check the bulb housings for corrosion or dirt then I'd look at the back of the bulb housings to see if a connector isn't hooked up or a wire broke off. If that all looks good you'll need to get a voltmeter to check the circuit.
Ah he beat me too it LOL
Also...
If you have access to another person with a 2G eclipse, see if you can borrow their taillight assembly and plug it up to yours and see if it still doesn't work, which means there is an issue in your tailight wiring harness, if it still doesn't work its an issue on the chassis side.
