turbo leaks oil to coolant question
Ben4g63t
Jan 18, 2010
Martinsburg, West_Virginia
It's been a while since I've posted and I have searched and even found somewhat of an answer to what i was going to try and do but my situation is a bit different.
My turbo popped a freeze plug one winter while sitting at a friends house. Its a 16g (water was left in the car from the turbo to oil cooler due to a noob mistake thinking that by removing the lower radiator hose all the water would drain out).
I replaced the head gasket, then the oil cooler, which was the real problem for sure.
Now it leaks coolant into the oil still and the only thing i haven't replaced is the turbo.
I have read a thread on here where people run their turbos without hooking up the water lines for one reason or another, they just leave the water lines disconnected on the turbo and run a turbo timer or just let it idle for a few mins before shutting the car off.
My first question is does this sound like something that can be rebuilt or internal metal cracked leaking the 2 fluids together that way and so the turbo is trash? Can I use another turbo like a junk 14b and swap parts from my turbo to it and make a good one? (I've never taken a turbo apart or even rebuilt one)
Second is, If I plug the coolant lines to the engine and plug the coolant lines on the turbo to catch any leaking oil, would that be about the same as running it with no coolant lines connected? It's possible that some coolant also was leaking into the exhaust system which would totally make it pointless to do any of this, but I don't know for sure yet and figured i'd see what you guys think.
I'm still a probationary member so i couldn't post this question anywhere else or i would have. I know u guys are pretty straight forward and brutally honest with replies sometimes but I'm hoping you will take it easy one me here.
Thanks again for any and all replies. Sorry for such a long thread too.
Ben
which freeze plug was it? if it has a new head gasket and still mixing after flushing both systems, then there may be a crack or something in there. some turbos don't have cooling lights. just oil. its something to try. put uv dye in the oil and at night go in with a uv light and see if you can find anything
Hmm after talking with someone a bit that rebuilds these he had me go look to see which 16g it was. So i wrote the numbers down and searched them on the site here and found its really just a 14b i believe.
49178-01 03 0 says tdo5 h on the opposite side (suppose a friend that saw that some years back jumped and said it was a 16g too soon...) and me being clueless just kept referring to it instead of figuring out how to make sure of this.
The person i was talking to also mentioned it was the bearing housing that was most likely damaged and would have to be replaced due to a crack or worse from freezing.
I guess the next question is...if this is really a 14b...could i buy a junk 14b with shaft play and be able to use my turbo and that one to replace it? Or does shaft play ruin the bearing housing as well?
^^ The freeze plug that popped out was on the bottom side of the turbo. (If it was still installed on the car.) It actually looked like coolant was running down the oil return tube when i first noticed I had a problem.
probably is cracked if the freeze plug popped off the turbo. just expanded enough to crack the housing.
as for the turbo, theres a 40-47 and a 52 in parenthesis. that says what the turbo is
Right on, thanks for the replies guys. Guess i'll look for a 14b to get this thing going.
