Maes
- 504
- 56
- Oct 20, 2014
Mishawaka,
Indiana
Wanted to get some opinions on my tune so far. I have base idle ideal as to the how to videos on ecmlink. This is more of a cruise tune. Any suggestions will help and if you bash that may also help. I know i need to get a wideband that is next on the list and to install the whole fuel system. Times are a little short and its only running 9-10 psi off the wastegate. Thanks
1). Any boost, vac, or exhaust leaks?
Boost leak tested 5psi above your max boost with no leaks?
Yes
2). Verified mechanical timing?
Yes
3). Verified base timing?
Yes
4). Ignition system
COP or Stock Coil: Stock
Wire brand and Age: Magnacore 8.5mm 10 years but maybe 1000 miles on them
Spark Plug brand, type and Gap: NGK BPR6ES, 0.28 gap
5). Motor health (Compression Test)
Cylinder 1:165
Cylinder 2:165
Cylinder 3:165
Cylinder 4:165
Need to do a new one that is from previous years but has been in storage
6). Performed basic throttle body adjustments?
Idle Switch: Yes
Throttle Cable: Yes
TPS: Yes
BISS: Yes
7). Compression ratio
stock i believe 7.8.1
8). Any known bad sensors or brittle wiring?
No
9). Any DTC/CEL codes?
No
10). Electrical system
Car off (not running): 12.6v
Car running: 14.1-14.3v
Base Fuel Pressure: 38.5
Injector Size (cc/min): 450
Sensor Brand: None yet
Calibration Date: None yet
13). Type of fuel
Type: 92 gas
Percent of Ethanol: 10
14). Watched ECMlink how-to videos?
yes
Yes
Yes
Yes
4). Ignition system
Cylinder 1:165
Cylinder 2:165
Cylinder 3:165
Cylinder 4:165
Idle Switch: Yes
Throttle Cable: Yes
TPS: Yes
BISS: Yes
No
No
13). Type of fuel
Type: 92 gas
yes
