DsmMickey
- 110
- 6
- Aug 18, 2014
Hamden,
Connecticut
First off, my grammar or sentence may be bad. Im done installing new fmic intercooler and big 16g, and fuel lab fpr. Now it finally start and i took it for road test. When i took off and trying to make boost, the boost gauge stay 0 so i figure that i got boost leak. I did the boost leak tester and found the boost leak. One is on j pipe, vrsf did bad job welding leaving tiny small hole on flange weld area. I email them 3 days ago but no response so i have to find someone who can weld aluminum. Anyway, while i was doing boost leak tester, i spray soapy on fpr, it does bubble up on top adjusting bolt and side fitting for vaccum, i try tighten up but still bubble up.
So having fpr bubble up after i spray on it, does it cause boost leak?
Having small tiny hole on j pipe and fpr (or if fpr normal) can make boost gauge stay 0?
