Galipso
Supporting Member
- 223
- 17
- Aug 23, 2011
Tampa,
Florida
OK so i've browsed these forums and can't figure this out. Some legit help would be huge right here.
Set up is 1G bottom end, 1G water pipe, 1G thermostat housing, 1G oil filter housing, 2G head
I've uploaded 2 pics, all color coded questions-
Thermostat housing pic:
Which one is the turbo coolant return line: Red or Blue?? Once identified, what is the other color for??
Green: Emissions Control Thermo-valve.... what does this go to? (ive eliminated the emissions) Can i cap it?
Engine Pic:
Purple is the turbo coolant feed line: Do i have to have the 1G OEM piece to bolt into it? (Yes the oil feed from the head is just above it but this will be removed since i've read it's a poor oil feed)
Yellow: is this the new turbo oil feed?
White: No idea what this goes to...
Pink: No idea what this empty slot is for...
Thanks in advance guys. Let me know if you need any more information.
Engine Pic:
