Help finding 1g auto performance motor mounts?
See the trans mount, front roll stop, and timing side mount all are 5spd Prothanes on my auto car. The rear engine mount however had to be left stock.
How about energy suspension bushings, prothane are nice too. If you can't get either you could temporarily use 3m window weld to stiffen that one bad mount.
I'm in the process of converting to auto, I have full energy suspension inserts already. From what I've found autos rear and front brackets on the motor are different but the mounts on the frame are the same as a manual. Also the trans is completely different in the height department.
I just now popped my insert out of my manual mount and stuck it into my auto trans mount. I still need to swap my brackets on the motor to the autos. Hope that helps , I haven't seen anyone who makes a trans mount yet.
The rear auto mount itself is a larger diameter. But it sits in the same location. Front and driver side are interchangeable.
