2G 99 ecu on 96 talon help
Talon96PR
Oct 24, 2014
Aguadilla, Puerto_Rico
New here and a little lost
I need help... I have a 96 talon tsi, I want to put a 99 ecu on it to reflash it, what I have to do?
Sorry if the thread is not where it belongs
Not really sure what your question is. You have a reflashable 99 ecu you want to put into a 96. For what reason? What are you trying to accomplish? Need more info. Also, unless you're running link the 99 will throw an I/M CEL most likely.
^^You can tune the 99 ECU. You can't run Ecmlink on a flashable ECU.
OP, as for installing the 99 ECU in your 96 I bought a 1g CAM sensor and used that instead of the stock one on my 95. You can also switch to a stock 97-99 CAM sensor but that will require the cam to be drilled and tapped unless you have a stock 2gb cam. The stock CAM sensor on the 95-96 don't place nice with the 98-99 ECU's.
When I install a 1g cam sensor what I have to remove or switch some cables or anything else?
What are the benefits put in a 97 to 99 ECU into a 95 96 gst or Gsx car.
I have a 95 gsx with a 1g cas with the plug play harness but my motor is a 97 is at ok with at set up or its bad to do at set up.
Sorry for the post but you have a good .?
You could buy the 6 bolt swap harness.
The benefits would be that the 98/99 black box ecu is flashable and its less expensive than ecmlink.
Where do I find the 6 bolt swap harness?
The car started and run but missed at 3k rpms
