2G Throttle Body Hoses
dizily555
112
3
May 30, 2013
North Mankato, Minnesota
Finishing up my engine bay and am stumped by these hoses. I have diagrams of what vacuum lines go where but these are nowhere to be found. Wondering if anyone could point me in a direction as to where they hook up. Thanks
I don't know if this is your issue but in 98 mitsubishi changed there evap system in the gst's atleast and put the canister in the tank rather than under the hood. They also changed around the vacuum lines this I believe is part of that newer setup. This also means there are two sets of vacuum diagrams. Also it appears to be part of your intake manifold not throttle body.
It is a 95 so the canister is under the battery in the engine bay. One of the lines has a fitting as if coolant were to run through it and the other is just a vacuum hose i believe and don't know where it goes. Im looking for someone how can find a picture or describe where they need to end up.
You made me pop my hood for this one. I have a 98 gsx and i do not have one of those on my car sir. Just look at the curvature of it and check areas that are within reach of it. Hmmmm. It had to run to some part of the intake i am thinking.
The pictures are terrable, but it looks like break booster at the back of tr manifold there, and in the front it looks like someone may be using the factory pcv port on the intake for a bov boost source, i did this on my car, but i also have a "carch can" where isnthat clear line going to from the back of your valve cover (pcv)
