djaux
- 53
- 4
- May 29, 2014
Myrtle Beach,
South_Carolina
Ok, have a check engine light., went to advance n it came up ignition coil. I have just replaced the wires/plugs(NGK). I've done quite a bit of preventative maintenance. It does feel like there is a miss somewhere.
Anyways, I'm gonna test the coils first make sure they're good. If it turns out I need to replace it, I will. I've looked on the forum, and basically the only answer that I've got is stay away from the MSD. There are couple brands that sell at the local parts store., BWD/Duralast/etc.
I have a 420a, so i'm not going to go over budget just for a coil pack. BWD seems the most popular(everyone carries it). The cheapest one was Duralast for 65. Or I can wait and order from Rockauto(was looking at the Wells)., but I won't get it till the end of next week. N I could use it now, being I've put new wires and plugs in.
I did spend about an hour looking up replacement coil packs and couldn't really find anything on the forums., idk.
Any suggestions...
Thanks DSM)
Any suggestions...
Thanks DSM)
