DarkPhoria
- 31
- 2
- Feb 24, 2015
South Gate,
California
Hey guys, just recently I put the engine back into my car and I noticed that it is "off". The engine is slightly tilted to the left and the heat reflector (the one that bolts onto the exhaust manifold) barely hits against the cooling fan. I turned on the car and it runs just fine. The engine mounts are all on correctly, so why is it that the position looks weird? I don't have any pictures right now but hopefully some of you guys can suggest the cause and fix.
P.S.: I read that bad motor mounts can cause the engine to droop down a few inches. If that's the case, then which motor mounts are recommended for someone on a budget but something that'll last a long time?
Edit: Just added pictures. Scroll down below to view my reply with the picture links.
