James_74
- 0
- May 4, 2015
Enfeild,
New_Hampshire
I have changed my valve cover gasket twice and it is still leaking. Has any one else had this problem? Is there a solution for it? The motor is a 420a.
Chips and dents can effect this in my experience.I don't think the surface is damage but I will check agen
This it's at napaJust use "the right stuff". That's what I use on my oil pan and valve cover never had a leak.
Have a 97 gst 4g63Also make sure your surfaces arent damaged and your bolt holes arent stripped. I only use rtv on my half moon thing on my 4g63 everything else is just oem gasket. Dunno if it's different for 420
You might need to do some mods mine will never leak from cap againHave a 97 gst 4g63
I've replaced gasket and oil cap. But I still find oil on top of the valve cover!
Hairline crack somewhere?You might need to do some mods mine will never leak from cap again
