phantom_19
- 410
- 2
- Oct 13, 2007
curacao,
South_America
Hi
I recently swapped my GS to GST with a full turbo engine. The harness I added some wires to the ECU. Car is on open headers as you can see in the video.Sound goes away once it started. The timing belt has a small streak due to a longer oil pan screw that has been fixed
https://www.dropbox.com/s/ekril3nvg3y9i66/20150515_100813.mp4?dl=0
When I crank the engine it makes a weird sound. Hard to explain. But I used another starter and it made the same noise.
Can you tell me what that is? The engine has oil. ACT flywheel with stock turbo clutch. ACT was working fine on my NT engine with no noise with the same starter. Starter is bolted securely to the manual gearbox.
thank you
thank you
