GSXDNA
- 256
- 14
- Nov 19, 2007
Los Angeles,
California
My profile is up to date, but for a summary:
Things I've checked:
Any other ideas on what it could be?
- 7-blade HX40, .70 a/r, T3
- Brian Crower 272/272 cams (otherwise stock 1G head)
- Stock valve springs
- 2.0L 6-bolt bottom end w/ (newer) oem 2g pistons, 1g rods
- Stock IM
- Intake/Intercooler piping leaks
- Spark plugs (one had completely black right with pure white tip - replaced that)
- Plug gaps
- Plug wires are all new(ish)
- Turbo shaft still looks good and has no play
- Reset the ecu (with the hopes I put it in some type of limp mode)
- Rocker arms are all still in tact and look good
