bigdnno98
- 275
- 38
- Aug 4, 2013
Clarksville,
Tennessee
Ok, so I'm not new to DSMs, big turbo cars nor drag racing..... With that being said, I'm having trouble building boost at the line and my 60' sucks on this setup. My profile is updated and all mods on there. I'll attach a log of the last pass I made at test and tune. 7.99@94 1.96 60' in the 1/8mi. I've tried the 2 step at 5500 and 5750 and haven't built more than 6.5-9psi at the line. I've messed with anti-lag before i put the Hoosiers on and just blew the tires off each time. I'm willing to try anti-lag again with the Hoosiers so if anyone is using it with good results can you please post your anti-lag settings?
So I usually attempt to do a burn out but the tires usually stick so I pull up to the line and stage first. I always shallow stage. When the other car lights his first bulb up I get on the 2 step and slip off the clutch at when the 3 yellows light up (pro tree). Again, best 60' I've gotten on this setup is 1.96. The car doesn't spin much, just a little chirp. It really just bogs off the line then when the turbo spools it takes off like a freight train.
Any help would be greatly appreciated as I'm tired of losing to Neons with 200 less HP.
