ECMlink someone with tuning xp take a look
Derek Goodreau
165
6
Jun 5, 2014
North Adams, Massachusetts
just bought a gsx, it has top end noise at high idle. having trouble keeping car running. i crank it over and it starts like 2 out 5 times or so, when running it idles at like 400rpms when clutch is engaged, 900 in neutral with clutch disengaged. and it wants to stall. when i drive it, it doesnt make it more than a mile because it revs loud but has very slow acceleration. when i accelerate as rpms reach about 3 or 4k there is a ticking noise that happens and CEL turns on, when i let off the tic goes away and so does CEL. Need help please! new to 4g63t.
Im completely new to ECMLink, and these are the values previous owner has everything set to, i wanted to make sure these are not settings that are causing this issue.
  • settings.2015.05.01-01.ecm
You should post a log so we can see what is happening while engine is running. You just posted your settings and you can't tell whats off until you can compare it to a log
Ok I will do that. And no I have not performed a Boost leak test.
