miliman13
- 1,957
- 276
- Jan 1, 2011
tampa,
Florida
Very nice build!!! Subscribe
Just curious about the rebuild kit and the borg clutches. Was there a specific reason or did price drive that decision? In the past, I used the alto and koleen with tremendous success. Their kits are reasonably priced and come with the band also.
Oh, what stall did you decide on and why? Did you get the center differential welded? I'm still on the fence about the center differential welding on my build.
Looking good on the build. Now clean those carpets!
Aaaannnnnddd here is my planetary.
Looking good! Is that the OEM 4g64 composite gasket?
Looking good Cory! What's the time frame when you think it will be done? We need to do some cruising this summer!
Nice, I didn't realize you were that close. I know a guy with all 3 of those .
Felpro makes a 4g64 dohc gasket? Have a part number? I'm pulling my head today to replace a cometic MLS 87mm. Have a felpro 4g63 composite on the shelf already to use; it's slightly bigger than my 87mm bore.
Doors open sooner than most. Good stuff! I ended up getting the same effect with a nut/bolt through the opening in the metal rod/lever arm to create the same effect.
Great looking build! building a forged short block as well soon.
