er82
- 243
- 28
- Apr 18, 2014
Sacramento,
California
I want to rebuild my 6 bolt with little cost as my goals for power are just 350hp. I took it apart and the cylinder bores are about 85.02mm which are near the limit. The pistons appear to be about 84.90 - 84.94 mm. So that gives it about 0.04 - 0.06 mm piston to wall clearance. If I hone the cylinders will that be too much with new rings? Or do I need new larger pistons and bore the cylinders?
