Antonio
- 31
- 0
- Apr 20, 2015
Baraboo,
Wisconsin
Hey all, long time on-looker ,first time poster. I have a weird issue with my TPS and I'm not sure what its telling me. First off car is 95 GSX. I recently finished my 6 bolt swap complete with RRE Harness ,1g cas, and a kiggly kit. Injector wires have been inverted at the ecu. I did not however swap to the 2g ISC. The car runs great hitting on all four , timing perfect, but at idle the car sounds like its cammed . If I unplug the tps and plug it back in it will momentarily idle to perfection, but 3 secs later its cammed again. I am familiar with tps settings and have set it about 20 times to no avail. Keep in mind this motor ran perfectly in my 1g for over 2 years setup just how it is now.
Thank you for your time, Tony
