brandonf90
- 100
- 4
- Oct 11, 2012
davenport,
Iowa
So I installed an aftermarket steering wheel in place of a 3g one I had in and when I install the wheel with the wheels straight the steering wheel is a little off center (tried moving splines) and it was still a little off center is there any way to adjust the steering wheel under the car like you see in a lot of jeeps (rotate a coupler that rotates (seperates) a shaft to turn the steering
wheel) or am I SOL
wheel) or am I SOL
