Evo IX Lifters for Tick
Still should be the 3G HLAs
Most have swapped to that style by now anyhow.
If your lifters are ticking it's like having a sewer drain that's clogged with garbage. The answer is not to make a larger drain so that the garbage doesn't clog it, it's to clean the garbage and figure out where it came from.
If this is "new" lifter ticket I'd make sure your oil filter media looked "clean'ish" before bandaid fixing with a bigger lifter hole.
