1G Custom engine harness
F_27stryker1
60
4
Jun 17, 2013
Elizabethtown, Kentucky
Started labeling and hacking apart the engine harness. Gonna get it down to the bare essentials. I've labeled and found most every connector but a few. Any clue as to what these two are for?
Also check out the hack job the guy before me did on the Ecu connector for an safc
Second one actually appears to be for the A/C dual pressure switch, not the A/C coolant temperature switch, assuming I'm seeing it correctly. This is based on the most obvious wire in the second picture which has a white stripe.
Appreciate it guys. gonna throw up pic of the harness shortly
Progress today. Getting everything labeled and taking out the junk
Thanks for that. I actually have that saved on my computer along with several other diagrams and pictures before I even started touching the harness. The most helpful to me was the link to the engine harness where you click on a box on the diagram and it showed a picture of the connecter and what it was, I'll seeif iI can find it and post it up for others
