Street Faze
- 118
- 1
- Feb 10, 2010
canton,
Ohio
92 talon turbo awd....I have a short that has led me to the cluster. I have test light on negative post on battery and clamped to chassis, light is on.
With the ecu plugged in, I pull the gauge fuse from under the dash and I immediately hear a buzzing noise. I now have ecu unplugged and with the fuse in, I pull the gauge cluster and that kills the short. I swapped clusters and no difference. I'm looking for a wiring diagram for the pins for the cluster(car side) need to know which pins should be hot.
Also, the post on the alternator is not hot, and both pins on plug for alternator are hot. Assuming one should be a ground? Where do these wires run to off the alternator? I can run new wire to whatever I need to, just need to figure out where point a and b is...
