Cynxe
- 265
- 6
- Feb 19, 2015
Ottumwa,
Iowa
It came off my friends car, he threw a rod and it held 350awhp, im still stock. His pressure plate had hot spots all over it too.You would have to measure is for wear. There is a spec for disc depth to the rivets. I do however see what appears to be abnormal wear on the outer portion of the disc from about 5 - 7 o'clock. Do yourself a favor and just replace the disc and TB. I would have the pressure plate checked out and the flywheel inspected and resurfaced as needed. If the flywheel needs resurfaced, you will likely need to shim the fulcrum.
