2g Chaos
- 0
- Mar 25, 2015
Reading,
Pennsylvania
So I have a 2nd Gen eclipse gst and I'm new to all this. I know I need to rebuild my turbo cuz it's spooling funny. Everything is stock. What turbo rebuild kit do I need to get?
I'm going off the cluster. I know the spark plug brand is bosch, but Idk what the gap is. Idk what CEL is. And the bov is recirculated. Everything is completely stock. I haven't done a single mod yet.
No. My bov is fine. It works properly.Is your blow off valve leaking oil or torn anywhere?
I'm going off the cluster. I know the spark plug brand is bosch, but Idk what the gap is. Idk what CEL is. And the bov is recirculated. Everything is completely stock. I haven't done a single mod yet.[/QUOTE
Maintenance before mods always. First rule of buying any car. Oil change, coolant, plugs, wires, air filter,02 , and exhaust gasket. Also a new timing belt, water pump, and tensioner is a smart thing to do. Git r done.
Thanks for the info. What size boost leak tester do I need to get?2g bov are known to leak and usually are junk. 1g bov with adapter for stock 2g ucip would be a nice cheap upgrade. Sounds like a boost leak to me, search for a boost leak tester. Also o2 sensors are cheap on amazon around 30 for a Bosch for front o2. Get some NGK bpr6es plugs and gapped them to .28
