1LE
20+ Year Contributor
- 1,347
- 4
- Aug 1, 2002
Sylvania,
Ohio
So, my DSM has had the cold start 10 second squeal going on for a few years now. It has recently also developed the squeal when the lights and defroster are on. So, I really need to get this fixed as that's unacceptable!
Belts are all tight and the water pump, power steering pump, and alternator spin pretty well by hand. So, I would have to suspect the harmonic dampener/crank pulley. Now, at the last timing belt change (perhaps 2 years ago) it was inspected by a shop and declared good. Today I went ahead and pulled it myself again (since the problem is getting worse). It really looks quite good (I see a tiny surface crack when inspecting VERY closely, nothing at all obviously wrong beyond that), but is at least 15 years old as neither myself nor the previous owner changed it. I hear other people have reported that replacing ones that look perfectly fine has solved their problem and I'm willing to throw the ~$140 at it in the hopes I'll have the same results.
My problem though, is that I see there are different part numbers for different year cars. '90-92, 93/4, and '95-99. I've got a '95 body with a '92 block... I really don't know which part to order. Is there some way to tell by looking at the crank pulley I have now (I looked, but didn't find any obvious part numbers on it)?
