Kod
- 289
- 0
- Mar 29, 2011
Kingston,
Pennsylvania
Well first here is everything that has been changed within the past 2 years (car has actually only driven maybe 12k?)
Spark plugs and wires (ngk single electrode remember seeing a post on that)
ISC motor, EGR Valve, and PCV valve from mitsu
02 Sensors changed 1 year ago and the MAF because old one was shot.
I just cleaned the intercooler out and still a SMIC hard piping from intercool to TB.
Biss screw and TB gasket use to have a boost leak but doesn't anymore.
BISS is exactly 2 full turns out and the throttle cable is adjusted correctly.
Fuel Filter replaced 1 year ago.
Sprayed starting fluid over areas I could reach with straw in and idle never went up so I am "assuming" if there is any leaks they are minor but still a leak regardless if there is any.
I do need to do another BLT but is there anything at all I could be missing because the car at times has power and at times doesn't. I do need to replace lifters with the revised ones because the ticking is straight annoying but I know that that has nothing to do with my issue.
It also has a here and there miss but not at all times..
The other day when it was on jack stands and in park I was revving it up slowly and it have like a little miss every 1500 rpm I went up but doesn't always do that.
Any help is appreciated.
Edit: I will try opening the ends up on the plug wires and I have some electrical cleaner I can spray the coils out with to make sure its clean.
I am pretty sure the gap is at 28.
