STM now stocks the EuroExport Valve Spring Compressor Tool !
STM tuned
Supporting Vendor
574
71
Feb 14, 2008
Rochester, New_York
We recently just started carrying the EuroExport Valve Spring Compressor Tool !
The EuroExport Valve Spring Compressor Tool is CNC machined out of T6061 aluminum, anodized black, and laser engraved. Its smart design makes it easy to replace valve seals, valves, springs, and retainers. You can even use this tool with the head on the block.
Made in the USA.
http://www.streettunedmotorsports.com/parts/euroexport_valve_spring_compressor_tool_40011_4g63.htm
We also carry the additional EuroExport Valve Seal Installation Tool.
http://www.streettunedmotorsports.com/parts/euroexport_valve_seal_install_tool.htm
Any questions reach me here via PM or give us a call! 585-226-8226
-Brian Gleason
www.stmtuned.com
Just used this last week, with head on the block. Awesome!
No-one should have shitty valves seals in a DSM because of this.
Can you PM me a price for both please?
^^^ i also want to know as i have this kit when they first sold it so no brad penn erm pen ;-)
Glad everyone likes the tool! Simple yet effective!
Stocking alot of these, so if you need it, give me a call!
-Brian Gleason
www.stmtuned.com
No-one should have sh**ty valves seals in a DSM because of this.
PM sent!
In order to change the springs/seals with this tool with the head on the block does it require pumping the cylinder full of air so the valves dont drop?
The EuroExport Valve Spring Compressor Tool is by far one of the best tools I've bought for working on my DSM (next to the Jay's timing belt tool kit), worth every penny. And FWIW, the rope method I felt is much safer then pressurizing the cylinder.
I bought mine along with the valve seal installer, I'm definitely looking forward to using it. I didn't believe the hype of the jays racing timing belt tool kit.....but after I bought and used one, never again will I be with out one. Hopefully this tool also lives up to the reputation.
I just got mine in yesterday and used it. It works fantastic and makes this job pretty easy. Now I have to figure out how to remove the spring seats that seem to be stuck to the head.
This is way better than the blue point "punch" type tool. I have both and will probably never use the bluepoint tool again.
A good tip for securing your valves once the springs are removed is to use small pieces of vacuum line on the stems to prevent them from falling into the cylinder when you remove the air pressure.
