2G drivetrain issue random 2wd(diffs,vc,axle?)
DSM Chase
778
51
Sep 19, 2011
Senoia, Georgia
Car starting sounding weird while cruising after spirited driving (digs) last night. Car felt like it wanted to bind In reverse this morning, on power it feels like 2wd and is all over the place, I jacked it up and all four tires spin when in gear....visually axles look good, t case looks good, rear diff, trans etc, No grinding noises.
Viscous Coupler, Center Diff, Rear?
center diff is the most common problem cause its the weakest unless you have a 4 spider gear one . i would drain the fluid and go through it with a magnet to see if you find any metal .
Have been to busy to check the fluid, the car is now completely slipping, free revving and roaring through drivetrain, clanks and pops when turning sharp...Ive narrowed it down to the front axles/Center or Front Diff.
