Resolved Innovate 3873 DB or 3845 MTX-L for ecmlink
The Innovate widebands play very nicely with ECMlink, so you'll be able to get it reading properly.
Yes, they come with two outputs which can be set for one wideband and one narrowband. However, with v3, you just need to input a wideband signal and the ECU can produce the simulated narrowband signal for you.
Ordered myself the mtx-l wideband. Thanks for all the help!:thumb:
I just installed my Mtx-l in front O2 housing last week and I really like it. Btw, in case you look up wideband installs be sure not to get confused with the LC-1. Make sure to use the yellow wire for NB simulation with ecmlink. It can be confusing because on the innovate LC-1 you would use the brown wire instead of the yellow.
Might you be referring to the tech article I wrote for the LC-1 install variations? If so, this isn't the first time someone has gotten them confused. I'm wondering if I should create another for the MTX-L (and any other variations Innovate has come up with).
I viewed your article and the info was clear. My problem was that I was looking at multiple install threads and got mixed up for a sec. It's odd that innovate switched the color of the output wires to the opposite. The other issue is ecmlink doesn't have MTX-L in the wideband options. I picked LC-1 and that worked for me. It's also difficult finding the correct switch point for the MTX-L. Thanks for creating that tech and I'm sure many others would like an updated guide if you have time.
A newer write up would great as I follow a lot of instructions from this site. Thanks again
