ErikTande
Supporting Member
- 1,505
- 560
- Dec 17, 2012
Centennial,
Colorado
Here's my results (dry test, engine warm)
113
119
117
120
I'm at 5300 feet elevation though, and I found this with a google search saying test results will be lower at higher elevation:
So applying .86 for my elevation, the corrected numbers turn out to be:
129
136
133
137
So am I ok on compression or should I be worried about the low numbers?
Thanks!
113
119
117
120
Compression Test Altitude Compensation Factors
Altitude Factor
500 0.987
1500 0.960
2500 0.933
3500 0.907
4500 0.880
5500 0.853
6500 0.826
7500 0.800
8500 0.773
129
136
133
137
Thanks!
