eclipsh
- 1,606
- 58
- Jun 16, 2005
Durango,
Colorado
I'm rebuilding my 2.4 and want to make sure I'm putting the right parts in for my target. I'm looking at ~450-500 HP as a goal. I have a 4G64 bottom end and 2g head. I've got Wiseco "9:1" pistons I'm reusing with new rings. Head has BC valve springs, a 3 angle valve job, ARP head studs. I've got 780 CC injectors and an Evo 9 pump.
I'm looking at running Eagle rods, 272 cams. I'm not sure what head gasket I should run or if the valve springs can handle 272 cams at a 7k RPM rev limit. I'm also not sure if the Eagle rods can handle 500 HP on a 2.4 given the rod ratio.
My other concern is the thrust bearing. At 500 HP there aren't a lot of clutch options and I'm concerned the heavy pressure plate will chew up thrust bearings. Any experienced advice on this? I'm thinking of getting a dual clutch system to save the bearings but that is an expensive solution. I have a 95 block so it is the old style thrust bearing.
If it matters, I'm going Holset for the turbo.
