95-green-gst
- 67
- 0
- Oct 11, 2012
ceres,
California
hey guys iv decided to part out my 2g. I have a lot of stuff to part out to much to list so pm or texts me (209) 505 0918 and ask if I have the part you need. Name's Jared. The motor has less then 1,500 miles turbo setup has less then 300 miles.
Block already .40 melted #3 rings left grooves in the wall might be able to bore it out not sure tho.
the head all oem parts is in good working order there's nothing wrong with it.
have the stock intake manifold and tb for it. $300
Turbo is a PTE 5431 has less then 300 miles asking $600 plus shipping
tial 38mm 2 bolt wga $200
v3 lite ecm with the sd plug and play and 4 bar map sensor $650
punishment racing intercooler kit $300 plus shipping
stock cam gears
gates racing timing belt
oem timing set
ss master to slave hard line
ss oil feed line
10 an oil drain with the an fittings for the oil pan and turbo.
oil pan
front case
water pump
stock fwd trans don't know miles but works perfect
the list goes on don't have the time to sit here for hours to put everything up. just ask if I have the part your looking for and ill let you know. call/texts anytime 2095050918 jared.
stock cam gears
oem timing set
ss oil feed line
oil pan
front case
water pump
