mbc double check
enriquez2000
2,277
820
Oct 5, 2014
fort collins, Colorado
Just double checking before i install... eliminate the "T" fitting by red coupler, plug the nipple on the intake, and hook the boost side of mbc to nipple on pipe in pic and other side to WG nipple... after that would i just unplug the bcs from its harness or should it stay in place? Just xhecking and rechecking before i go for it.
If you unplug the bcs harness, you may get a CEL. Leave it plugged in electrically, but disconnect the vacuum lines. Make sure the vacuum source line is capped, if you are not reusing this line.
From my pic the mbc would just go where the t fitting is now right.. of course id need longer lines
