Nate355RS
- 446
- 50
- Oct 25, 2012
Salem,
Virginia
I'm pretty sure my EGT gauge is reading high and I'm wondering if anyone else has run into this? It was installed by the previous owner and the probe is in the exhaust manifold and I don't know what brand it is. But under cruise it reads between 1500-1600 and when I go WOT it will usually be up over 1800.
I don't have any exhaust leaks or boost leaks, and my WOT AFR is 10.5 with 0 knock. The motor has good compression and seems healthy so I can't imagine the EGTs are actually that high.
