Kyle McL
- 62
- 0
- Jun 28, 2014
Rierside,
Pennsylvania
This may be real dumb and hope I am posting this in the right area. In the photo I am assuming this involves the clutch. The small tank in the photo. What is it? How much fluid should be in it when the car is off? What kind of fluid should I put in it? I originally am looking into the clutch since the car rattles when the engine is revved and stops when the clutch get presses in. It still rattles but not near as bad when pressed. I am hoping adding fluid will fix to this tank if I am correct will fix the issue.
