eclipto98
- 61
- 1
- Sep 7, 2014
lodi,
California
So i just got my plx dm-6 gen 4 wideband combo and will be running a narrowband simulation with link but had some questions.
1. how many have put the wide band in the stock o2 location without problems.
2. when tapping into the o2 pin for the ecu can i just pull the wire back or do i need to cut it and splice.
3. wheres a good place to run the wire from the wide band to the module inside the car
4. where should i pull power from.
5. when using a narrow band simulation i only need to use the wideband input correct.
6. when using a resistor for the o2 heater wheres a good location to put it.
ive searched and coulndt find direct questions to my particular answers
