darknezz7
- 571
- 80
- Mar 30, 2014
Eugene,
Oregon
So I thought I did not bolt on #19 and 20 to the block for the turbo coolant
but then when I got down there I realized the 4g64 block does NOT* have that spot.
So will this work if I put a T here? The braided line is coming from bottom of the oil housing, the black tube from the bottom of turbo. both turbo and oil tops are feed from water pump coolant pipe. So the water should be flowing the right way?
Or what should I do?
This is the last issue and system to seal up before driving status...
