eclipto98
- 61
- 1
- Sep 7, 2014
lodi,
California
im having some major issues with the idling in my car, everything ran fine yesterday morning but the same night before i left to work my car took a long time to start, after driving it 30 feet it stalls and would not start, so i hooked up link and for some reason all of my settings were changed so i changed them back drove to work then it happened again on the off ramp.
I had a bad ground so i fixed that but now after the car heats up it idle surges higher and higher until it stalls. if i give it gas it dies right after. i checked my plugs, and cts both seem to be working i dont have any major boost leaks. and the biss screw has been the same. but now my o2 is reading 0.00 now but before it was at a steady .02 volts
any help would be great
i uploaded 3 logs the first one i let it heat up. the second one was starting up after it stalled
