So I'm under the car and I see this...
Roberto Creator
Oct 20, 2014
Omaha, Nebraska
I'm under the car right. Ow, replacing the slave cylinder, and I notice what appears to be a fu©$&d up engine mount. What do y'all think?
It's called a Roll Stop Mount - to keep the motor from "rolling" forward when it develops torque. Some users just replace this with blocking up the motor to relieve the weight from it, to putting and gluing in urethane inserts in the middle to build it back up.
If you see one with the center bolt all the way to the bottom and can't be lifted up, the under center brace has been banged in due to previous users "pancaking" the vehicle and bending up that center brace.
use these:
Irwin / Hanson / Vise Grip (HAN394002)
5 Pc. BOLT-GRIP™ Bolt Extractor Expansion Set
I have rounded many bolts including the same motor mount bolt that you are working on! These work every time and are available at Sears , Advanced Auto Parts or Auto Zone!
If roun
use these:
Yea those things r lifesavers! They have pulled me outta hard spots at work quite a few times, if its stripped out on the inside and just spinning on the stud u can try to get a flat head screw driver or something similer btween the frame and nut and push up while u turn, cut it off, or torch it off
