buhay6
- 1,661
- 63
- Jul 9, 2010
Delisle,
SK_Canada
Ok to explain a little I cant get my stupid engine to base time. It will either advance one tooth or retard one tooth, swapped belts as well to rule out a stretched timing belt and still no go.
Engines all stock
Will have the cams set and locked in position but the crank sprocket teeth will always line up with the teeth on the timing belt not allowing it to go on unless advancing or retarding the timing.
So pissed off I want to just burn this dumb car, spend 4 hours fighting with this and I've just about had it.
anyone have any idea's?
Engines all stock
