purpleeclipse3g
- 0
- Oct 23, 2014
Westerlo,
New_York
This is going to sound really weird but I do not own a dsm, I have a 2000 3g rs that I am doing the evo swap to I a using a 2g gsx rear subframe and gas tank and axles if I can find them. This is my question why are NON LSD axles so hard to find, I have called 4 different parts stores and numerous salvage yards and found nothing. The driveshaft shop has part of the axle (shaft and outer cup) for $800. What do you guys do when you need new rear axles? Also is it true that most eagle talon tsi 95-96 were on lsd rear ends? I need the non lsd rear axles to move forward with my project and am in a major bind because they are as common as unicorns. Any help would be greatly appreciated thanks.
