Kyle_T
- 795
- 12
- Oct 19, 2008
Muskego,
Wisconsin
I've got a tial mv-s 38mm wastegate off the o2 housing. The turbo is a td05 16g with the evo3 turbine housing. The problem I'm having is the wastegate is not controlling boost levels at all. I bought brand new tial springs from extreme psi. I bought the 1 bar(14.5psi) springs. But yet when my turbo starts to spool I see my boost gauge spiking to 20-25psi and I immediately let off the throttle.
I have the plugs on 2 of the bottom ports and the vacuum fitting on the other. Both top ports are open. Only think I can think is, I replaced the aluminum crush washers with copper ones and maybe they aren't sealing completely, creating a leak. Any way I can test to see if its opening at all? The diaphragm looks fine also.
