Removable steering wheel legal?
David199619
50
Jul 19, 2012
East Bangor, Pennsylvania
Are removeable steeing wheels legal considering there is an air bag in the OEM steering wheel? If so, which would you recommend? I want the removeable steering wheel because that is basically the ultimate theft deterrent, and I am short so my seat is really moved up and it is hard to get in with the steering wheel.
I would recommend keeping the factory air bag unless you plan on going to a full on harness. As for theft determent, a fuel pump rewire with a switch at the relay is a good idea. Not only does it improve voltage at the pump, but also disables the pump if switched off.
It is legal to change it. And I agree aabout the theft part ! Also if if it's something you want to do just because you like it then I say go for it.
