Drag Race Build 1993 CC Lancer(Mirage) FWD All Motor and Turbo Build
robevo
87
17
Aug 9, 2006
Brisbane, Australia
I thought I would put up a build thread on my CC Lancer Coupe(that's what we call it here in Australia)
It all started when I bought it from a friend of mine as a roller with a cage/chute lexan etc.In its former life it was a turbo manual running mid 9's at over 150mph. He was over it so I snapped it up.
My first goal was to put in an auto/turbo on methanol set up and have it run 9's etc, so we started on the engine build.
I sourced a 2.4 block and started to do the prep work on it.The bottom end consists of a 2.0 Manley crank, GRP alloy rods and CP flat top pistons 9.8:1 comp.So we ended up with a 2.1 long rod(6.300) 4G64. billet_crank.jpg20140901_154617.jpeg 20140901_154538.jpeg
The cylinder head has the usual fruit o/s valves cnc port job, bee hive valve springs/titanium retainers and 290cams.
Now that the engine was assembled it was time to start on the fuel system so we went for an alloy fuel cell at the front and an areomotive mechanical fuel pump set up running off the crank.Injectors consist of 1600cc indy Blue.
Suspension is Koni Shocks with 1000lbs springs in the rear 15X26X10 M/T slicks with convo pro wheels 15X10 with a 5 inch back space.We fabbed up some traction bars out of moly and ran them to the middle of the car.
20131108_121532.jpeg 20131217_104019.jpeg 20131217_103839.jpeg 20131108_121619.jpeg 20131217_104031.jpeg !cid__20140612_111821_.jpg
The engine was mounted to a built auto with a re stalled converter and we started to fab up engine mounts and piping. We decided on no intercooler as we are running methanol as the fuel.The turbo I chose was a Garrett GTX3076 with a HKS wastegate and turbosmart Eboost. The intake is a standard Hyundai Sonata Throttle and Plennum. On the stall it makes 15 psi very quickly and wants to start to creep. The end result was 570hp at the front wheels on 26lbs boost with the hyundai intake.
Engine management consists of a Haltech E11 which I had lying around, MDS DIS4 CDI and a KOSO dash(after market motorbike, awesome dash!!!)
So I was ready to go racing, I found out I needed to get everything re Tech Inspected and my Drag Licence was expired. I was running out of time for our biggest meet here in Australia(the Jamboree) as I knew this would run over 140 and into the 9's so we embarked on version 2 for the meantime.[DOUBLEPOST=1409566637][/DOUBLEPOST]So version 2 was something I wanted to do for a long time and build a tough N/A 4G set up.So what we did was take the turbo set up off and make an exhaust manifold and put on a hypertune intake manifold and a 100mm throttle body.I kept everything as it was.20140901_133048.jpeg20140901_133057.jpeg 20140901_133108.jpeg[DOUBLEPOST=1409567975][/DOUBLEPOST]I put a manual transmission back in and a twin plate clutch, strapped it back on the dyno and it mate 250hp to the front wheels.I had a feeling the ratios are too tall for the power it was making, but that was all I had at the time.I bolted up a pair of 13X24.5X8 slicks and it was off to the track. We weighed the car with me in it and it came up 2090lbs(im 260lbs)The result was a great day and I had a blast
pass 1 [email protected]
pass 2 [email protected]
pass 3 [email protected]
pass 4 [email protected]
pass 5 [email protected](backed off bracket race)
pass 6 [email protected](lost by .082 sooo close)
I was 60' in the 1.7's all day too.
As I thought my ratios are way too tall
[DOUBLEPOST=1409568080][/DOUBLEPOST]Future mods shorter ratios and more compression and start hunting down 11's and maybe a 10
Good to see you start this thread. You do not see N/A mitsu powered cars very often. This might open a few doors for some people.
What are your goals with this N/A setup?
I want to run a 10 sec pass all motor, so I did some calculations and I need to make around 330-350hp at the engine(2100lbs)
and that should give me a 125-128 trap.So my next meet is on the 20th this month and I am going to change my diff ratio
to a shorter one and see what this does.I also have some 22 inch slick I want to try too.So the next outing I will do a couple of passes
with my 24.5 inch slicks and then bolt up the 22's and see what that does.
In the meantime I am going to build another bottom end go bigger with displacement and go nuts with the compression.
I think 10s are doable. Ive always wanted to try a high compression LR2.4L But all I have laying around is 1Gs and finding a 2.4 block for that chassis is a pain.
What cams are you running, any info on them?
Very nice, your plans sound like it will work.
I tried to look up the intake , but what I am getting is American Muscle parts, is this available through them?
Im running an off the shelf group a rally cam from tighecams.com.au and they have around 290 duration im not too sure on lift.As a turbo it was awesome so with a little bit of cam dialing
I think these cams might work fine. The intake is http://www.hypertune.net/ and is a very popular item on many cars here in Australia.
We have the same problem with finding 2.4's here too, so Im in the process of trying to find one.
Shorter diff ratio is in(evo3) and I am going out on Saturday again, hoping to run an 11 sec pass
Ended up doing 4 passes 12.022@115, 11.92@115, 12.04@117, 12.2@116
Finally an 11 sec pass woohoo.
