87 Galant RalliArt 2.0TURBO 4G63BT
tomica93
68
53
Aug 22, 2013
Zagreb, Europe
Hy there, here is my car, rare Mitsubishi Galant from 87
1987 Mitsubishi Galant 2.0Turbo RalliArt
Odometre
127xxx km
Engine Hardware
4G63BT- 2.0T
227HP
Transmission
5 Speed MANUAL
gearbox from 2.4engine(4G64)
Engine Modifications
Megasquirt 2-Extra
Blow off-Turbosmart dual port
boost is on 1.0bar
exhaust 60mm(rear REMUS muffler)
intercooler
walbro 255lph fuel pump
intake box & k&n filter
Aeromotive FPR
450cc injectors
innovate lc-1
intake manifold from 4G64
intercooler pipes from steel and polished
second ventilator for better cooling
water cooling for intercooler
eclipse coils
hks turbo timer
Brakes:
wilwood 4pot brakes,310mm slotted and drilled willwood discs + ABS
Suspension Modifications
Front:
Sport shocks+Sport Mazda626springs
Strut Brace
Rear:
Standard 2.0
strut brace
Wheels & Tyre Modifications
17" original from Galant Ea0 Sport edition 1999
205/50/17
Exterior Modifications
Rain visors for front doors
Ralliart Body kit
white corner lights + white bumper turn signal
RalliArt original side stickers
Interior Modifications
power mirrors
power windows
red light illumination
Boost gauge,oil temp gauge,afr gauge
Future Plans:
bigger turbo...
On begining it was a stock 2.0(4G63) carb
Then i got a ralliart body kit
Some polished stuff
So i put in a better engine 2.0turbo ECI with 150hp
so again, i started to replace a whole wireing
complete head was checked and restored by me
also valve cover is from 2.4 engine and polished
battery moved to trunk
headlights and side lights were totally restored again by me
this is how it looks now
innovate wideband and megasquirt II
Fog lights are working now
New Depo Boost and Oil Temp Gauges
Aeromotive FPR installed with gauge
on CAS sensor it is now high resolution plate 24:1 tooth
shift light is also added
wireing a megasquirt2
it has great fetures now, such as launch contorol, flat shift
results
226,5 HP
348Nm
engine turned 125000km
some profess photos for the end :)
finally, i have bought an engine from 1g Eclipse AWD turbo
now iam collecting parts for regular service, and also for some small mods :)
New injectors from EVO 4 , 510cc , with 69kkm
One picture in nature
and then there was a burnout with old engine
one video
[video=youtube;e3zZHIs6hL4]
New alternetor for DOHC
After clening it up, and polishing a bit, here is a result
fuel line for DOHC
And then, a party time
next step was connecting a wires CLT, IAT , TPS and CAS sensors, CLT and IAT are the same, while TPS and CAS are a bit different
also, TPS needs calibration
one video after TPS was connected
[video=youtube;NekZojCvryw]
CAS opened, and a 24:1 tooth is putted in
Friends are always ready
Engine in its place
Video of a first start
[video=youtube;zp9TLSSUqag]
Compression test, by cilinders
1.145psi
2.147psi
3.145psi
4.144psi
and engine is putted on an homemade engine holder, to be easier to make a big service and cleaning it up a bit
wastegate is polished
new gauges from evo 9 MR
installed red illumination
then balance shafts are out, total weight save is 2.9kg
then the cleaning part
valve cover was in pretty bad shape
piston before and after
then next part was block
painted
thanks guys :)
new OEM parts
head cylinder is dissassembeled
exhaust valve, before and after
washed oil pump
all pistons are cleaned up, after 15washes
all is washed, and ready for install
valve cover painted
painted exhaust manifold, turbo housing, o2 housing and covers
oil pan cleaned up and painted, also a timing cover
DSC02123Kopiraj_zpsa509ba0d.jpg[DOUBLEPOST=1412588467][/DOUBLEPOST]galvanized bolts, and lines :D
lines looks like they are cromed
and how it should looked on the block
Main water pipe is now rust free , and completely galvanized from outside, as well as inside
Just received a package from jnz tuning
Mitsubishi Genuine parts
ACL Race bearings, Perfect Circle Rings
All parts collected so far
Rings
finally I restored original RalliArt 15" wheels
some tool that came in
then i made another valve cover set
painted
then i got AMG cover
il cap restored
also a clear timing cover came in
and a final result
machine work done
honed and surfaced block, surfaced valves, surfaced head, and a polished crankshaft
how it should look when i will start assembley
then i got mitsubishi eclipse 3g lifters
difference between 1g and 3g
next is cleaning, and working on a port job on the oil gallery on the block (where oil pump sits), by that i mean on a smoothing the surface for better oil flow
installed in crank with piston and rods, head to block dowels, ARP headstuds
acl race vs OEM main bearing
rings and bearings are installed
